January 29, 200620 yr Can a 4WD EA81 Tranny fit in place of the FWD tranny, and which clutch and flywheel needs to be used? Can that tranny fit and run with no rear driveshaft attatched?
January 29, 200620 yr yes, except, the driveshaft helps to hold in the tranny fluid. sitting level, the fluid will not leak out with the driveshaft removed....but if it's tipped even slightly back, it will, so I'm sure it would if you were driving.
January 30, 200620 yr So what you mean is not "yes except...." but rather "no, because...." no, you could just mount the front half of the driveshaft......I'm sure there are ways around it....
