86ROO Posted February 5, 2006 Share Posted February 5, 2006 Has anyone taken a wrx tranny apart with the posi and try to fit the posi in a d/r tranny Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted February 5, 2006 Share Posted February 5, 2006 The WRX didn't get a front LSD, but the STi with the 6MT did, but it won't fit. you can get an aftermarket one, 1000-1500, or you can get a phantom grip, which is around 400, but that has gotten mixed reviews. Quote Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 5, 2006 Share Posted February 5, 2006 is the front diff like a standard Nissan one? I know the rear is the R160 or something like that; and I know the front is larger; I just know that there were LSD's available for Z cars, and that they use a larger diff - if their rear diff is the same size as our front; we may be able to adapt it to work Quote Link to comment Share on other sites More sharing options...
86ROO Posted February 6, 2006 Author Share Posted February 6, 2006 that would be cool if we could adapt a lsd from another vehicle. I email a company call right-loc they make a clicker posi like the detroits and he said that I would have to get a lot people to want it designed to keep the cost down for manufactoring and the minium number for the order was 70 units. Its a cool setup all you have to do is replace the spider gears with the right loc setup , there are no shims or special lubs to use. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted February 6, 2006 Share Posted February 6, 2006 The rear LSD won't fit, there was a huge post on this about 2 weeks ago that covered this topic. The bolt circle won't fit from the 160, its totally different. Quote Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 6, 2006 Share Posted February 6, 2006 The rear LSD won't fit, there was a huge post on this about 2 weeks ago that covered this topic. The bolt circle won't fit from the 160, its totally different. I am WELL AWARE OF THAT - the front diff is much larger than the rear diff and the 5MT front diff is larger than the 6MT front diff - the idea is that as the Subaru and Nissan 160's are basically the same diffs (in fact they are interchangeable) - Nissan also made a 180, and a 200 - LSD's are available for both diffs - the question is if the Nissan 180 or 200 LSD would fit the front diff, or if the LSD case from one could be redrilled to fit the stock Subaru crownwheel Quote Link to comment Share on other sites More sharing options...
