February 19, 200620 yr Hi*** I might be able to pick up a full setup (Shocks, spriongs, topplates) from a 2001 Outback for cheap. I need to change my suspension, but I am wondering if it would fit. I do think so, but just in case, anyone with experience ? Thanks JFD 93 Legacy Wagon Non turbo, 5 speed 2.2
February 19, 200620 yr search for outback/forester lift... fronts will bolt in no probelm, rear will need your orginal strut tops on the new struts, or strut towers will have to be slotted out. do it to it
February 19, 200620 yr I was under the impression that the 00+ Legacy/outback had a completely different rear suspension.
February 22, 200620 yr Author I was told to use any 95-99 Outback setup. I have found 2 front-2 rear 97 Outback whole assembly (struts, springs and topplates for 75$Can each. Is it a good deal ? They are guaranteed 3 months from a reputable Subaru used part junkyard. Cheers JFD
