Someone help me cuz napa couldnt
I have a 1990 loyale turbo automatic. I need a new axle and ordered one from napa. It wasnt the right one. The 1990 loyale has a beaffier axle then my 87 GL, they are not innerchangeable the 87 is too small to fit around the tranny stub, the one that napa got me fits the 87 GL but not the 90 loyale. Does anyone know a part number for these axles because napa does not, and neither does subaru of kirkland. They are all unable to distinguish the my 90 axle from the other one. Thank you
you need a 25 spline axle. tell them that. have them pull up a axle for a 88 turbo wagon with a automatic. that should be the right one.
The axle they gave you was a N/A Loyale which is a 23 spline axle
they gave you an axle for a 3spd automatic. all 3spd ats were 23 splines, including TURBO 3at. the difference is the turbo 3at axle is the same diameter as the 25 spline axle but has 23 splines
if the axle doesnot fit your turbo then you must have a 4spd at, or FULL TIME
if thats the case mention full time 4wd, or ask for a 5spd turbo
In order to get a 25 spline axle for my car, I had to look one up for an '88 RX. Their computer should say 23 or 25 spline, and if it says 23 spline, there's no way it'll work.
Autozone couldn't get a 25 spline axle at all, and Advance had to look at all kinds of stuff before we could find one. Didn't try Napa.
EDIT- on second thought, I have a compatible axle sitting in my storage unit right now. It's used, but there's nothing wrong with it. If you needed, get in touch with me and we can work something out.
Exactly.
If I need something turbo related, I order for an RX
If I need something wagon related, I order for a 93 Loyale. Its the only way I can get the right parts for the turbowagon.
