fbh Posted February 28, 2006 Share Posted February 28, 2006 sup folks, I'm in the little corner of the world known as New Zealand. Does anyone know where I can find new shifter bushings? Also, does anyone know how to remove the linkage? it almost looks like dropping the gearbox is required. And on another note, what's the easiest way to apply a short-shifter mod to this model? ('89, EA82, D/R 5-spd P/T 4WD) Link to comment Share on other sites More sharing options...
BobBrumby Posted February 28, 2006 Share Posted February 28, 2006 Try you local subaru dealership. Short shift mod: cut the shifter down , I dont think there is any aftermarket kits like there are for the newer soobies. Link to comment Share on other sites More sharing options...
NuclearBacon Posted February 28, 2006 Share Posted February 28, 2006 http://www.ultimatesubaru.org/forum/showthread.php?t=45884 I cut the bolt with a hacksaw, got a new bolt *4 bucks from the subaru dealer* dilled out the hole to be same size on both sides, then drilled a hole on the inside of the car to pass the bolt through... 2 washers, and the original lock nut, and my subie shifts AWESOME! otherwise, yeah, get ready to take the drivetrain out... Link to comment Share on other sites More sharing options...
