March 2, 200620 yr I just moved to Pa and went junk yarding. My local j/yards are littered with newer forresters and legacy's. I was just wondering if any of the parts would be compatible with my 87 gl10. I am especially interested in the brakes and hubs. A big brake conversion would be nice. Possibly the front stuts as well.
March 3, 200620 yr the ea82 strut cap SHOULD fit on the ej strut, thus not having to slot the holes. the axles will be 25spline,the proper lenght. 2wd impreza 1.8, 91 legacy 2wd AT are 23 splines work may involve the tie rod ends. the ball joint hole may need drilled out, can use xt6 lower control
March 4, 200620 yr Author the ea82 strut cap SHOULD fit on the ej strut, thus not having to slot the holes. the axles will be 25spline,the proper lenght. 2wd impreza 1.8, 91 legacy 2wd AT are 23 splines work may involve the tie rod ends. the ball joint hole may need drilled out, can use xt6 lower control So the axles will work with my d/r swap? Or will I need to change DOJ's? The one I am looking at is a 98 Forrester EJ25.
March 5, 200620 yr Author Can you find out how much a full set of forester springs would be? Sure, give me a few days, and an IM so I dont forget.
