October 20, 200322 yr I pulled a high rise center console from a 2dr GL10 Coupe today, and so far I've got the switches mounted, but i still need to paint the panel and prep the console alittle. Pix! I had to use my dremel to cut alittle away from the existing panel. There it is with 3 out of 4 switches. I need 4 total switches, but so far I only have 3. There's the complete center console. I'll probably leave it grey, but the switchboard will be gloss black. Still need to find a way to mount the switchboard since i removed the original switches. -Brian
October 20, 200322 yr Oh, that looks like such a good idea. I'll have to throw that on my list of things to do when I get that new Sube... If'n I remember right, the old archives had a thread that mentioned switches with lights embedded within 'em, available at Radio Shack. Create a custom decal for the switches, and it might be pretty interesting. Now all we gotta do is figure out what to hook 'em up to
October 20, 200322 yr Author I have 8 lights to wire, so thats what these switches are going to be used for. I will have one large MASTER switch that will go in that lonely hole in the bottom, and that will turn EVERY light on at the same time. -Brian
October 20, 200322 yr and that will turn EVERY light on at the same time You're going to need two community alternators. :-)
