Brumby Boy Posted March 17, 2006 Share Posted March 17, 2006 Hay all my brumby wont idle about half way home yesterday arvo i pulled up at lights and the engine died restarted noworries and runs fine now every time i pull up at an intersection etc the enging dies any ideas? Quote Link to comment Share on other sites More sharing options...
azsubaru Posted March 17, 2006 Share Posted March 17, 2006 Maybe a bad idle switch Quote Link to comment Share on other sites More sharing options...
suburpy Posted March 17, 2006 Share Posted March 17, 2006 For mine - classic symptoms of blocked idle circuit in carby (if u have a carby?) I have just had both loyale and 84 wagon die when pull up to lights etc. On one I could see that the idle circuit in carby was so blocked fuel was leaking into the secondary circuit and going everywhere, pretty easy to spot that petrol outside the carby. Rebuilt them both and they idle fine now. I think this is why many people opt for the weber carbys? Quote Link to comment Share on other sites More sharing options...
82Brat Posted March 17, 2006 Share Posted March 17, 2006 also make sure carby mout bolts are tight--no air vaccum leaks Quote Link to comment Share on other sites More sharing options...
Brumby Boy Posted March 18, 2006 Author Share Posted March 18, 2006 Had some time today so i replaced the plugs, leads, dissy cap and rotor id runs a bit smoother but not related to the idle problem. i cleaned out my carb and adjusted the idle screw it idles ok now but i am looking for a jy webber 32/36dgav so i should have it on fairly soon but thanks for the replies. Quote Link to comment Share on other sites More sharing options...
