more fusible link info...
i think i did something smart but i welcome your opinion in case i'm overlooking something
didn't want to replace the fusible link and have it continue to blow at $9 a throw so i bought a wire with an inline, replaceable 30 amp fuse to repalce the link until i can be reasonably certainthe problem that is making the link cash is fixed.
<$5 for the link and 6 30 amp fuses
will this work o.k. or did i forget something???:slobber:
thanks,
gregg
You'll certainly protect your wiring with a 30 amp fuse.
I would be surprised if the headlights work with just a 30 amp'er in there, if it's the main link.
they also sell fusible link wire. buy a roll of fusible link wire for a dollar or two and make your own fusible links with the original end links or standard electrical ones off the shelf will work too. i've done it. a handful from the junk yard for 50 cents is nice too if you have the time. they are standard across a zillion models, years, and engines.
