by ************akchi hello weber
after breaking a $100 plastic piece of BS for the hitachi to run I went to the JK and picked up a 32/36 weber with electric choke..looks like I'll lose quite a bit of vacuum hoses:banana: :headbang: then I looked at it and realised exactly how much bigger its mounting surface is compared to the hitachi Im gonna be making an adapter my question is what is a good height for adapter to be?Id rather not cut the hood to make it fit when Im gonna run a snorkel to the roof.:headbang:
I believe that the redline adapter is about 1 inch in height, although if you've lifted your rig, you can make one taller and increase the plenum volume, however that will mess with your jet settings, and you may have to go bigger or smaller depending on how it effects your vacuume signal.
