90 Legacy only has 1st gear
Greetings All,
I just picked up a cheap 90 Legacy that has automatic transmission issues. It will not shift into reverse, 2nd, 3rd, or 4th. i.e., when I put the shift lever into D, the trans goes into first and will not shift up. Fluid is full and unburnt, and the TCU is not throwing codes. Any ideas on a fix?
Thanks,
Tom
You need a transmission. Either the clutches are gone or the internal seals are gone. Either way it needs a trany, its mechanically shot.
nipper
