Ea82 Shortshift
Is there any way to make the EA82 short shift, when racing one looses so much time while changing gears any1 tried it b4 with pics of how to go about it.
Thanks
I know you can make a stock shifter into a shor throw, I have done it by moving the pivot point up on the shifter about 3/4". I also chopped my shifter as well to make it sit lower.
here's a picture for you of before and after
doing what Caboo says about
raising the pivot point
you must also bend the connecting rod on the
left
:banana: Finally got the short shift done its not all that but its way better then before thanks for the info.:headbang:
nail me for this... and laugh as you will.. but welding is involved to move correct ;)
I did weld it believe me it was no joke first I added a piece of steal about
1 inch when I fitted it back it was too long so I decreased it by half an
inch fitted it I lost fifth and reverse so that meant the I lost the angle
damn any way this time I was little more clever should have thought of it
at first I cut it again welded a bolt on 1 side and the other a nut so a can
adjust oh and another nut to act as a lock nut then it was k apart from
the adjustment finally I got it!!!:headbang:
Nuke,
The way I have it done is to first remove the bracket using a angle grinder
I then position and reweld the bracket up about an inch (see picture)
The next trick to retain the proper angle and to clear the floor is to bend the connection rod.
It is pictured on the left. I heated it with a blue tipped hot wrench (oxcetelene torch)
This method retains the factory pivot ball at the bottom of the shifter.
New bushing at this location also help tremendously.
Hope this helps.
thats rad... i'll have to look into this...
maybe someone could get ahold of the dimensions and send them over to subydude to have him machine something out... how rad would THAT be!
AIM: DaSubyDude
