April 20, 200619 yr Started out fuse blew on power door locks, put in a new fuse, now the park lights flash as if emergency flashers are on and the doors lock and can only be unlocked by the key, the buttons do not work on the inside. please help. Dennis
April 20, 200619 yr I know on mine that the parking lights flash like that when the battery is unhooked. To stop it, you need to lock/unlock the car with the keyless entry. Check for a sticker under the hood. If your car has keyless entry it will tell you how to stop the flashing parking lights.
April 21, 200619 yr Author I know on mine that the parking lights flash like that when the battery is unhooked. To stop it, you need to lock/unlock the car with the keyless entry. Check for a sticker under the hood. If your car has keyless entry it will tell you how to stop the flashing parking lights. THANKS A BUNCH YOU WERE RIGHT ON TARGET. HOPE TO RETURN THE FAVOR DENNIS
