Which ECU's are interchangable?
I'm going to head to the junkyard and look for one to pull.
I'm driving a 88GL MPFI Turbo. Can I take one off of any MPFI car?
My ECU has a bunch of numbers on it:
Big font: 20
First top box: 22611 AA410
Bottom left box: A11-000 R15
Bottom right box (stamped): 8118
Help much appreciated!
-Hamish
i just got one from a 86 mpfi xt ,will sell cheap + shipping if it will work for you
try to match them, because a non turbo ecu will not work, fuel curve and timing control is different.
good luck
-Hamish
NO,pre 87s won`t work.I`d stay away from XTs too.
You want to match this #.22611AA410.
Unfortunately that # is unique to 1988 49 state non-XT turbos.
Not positive whether an 88-9 calif. turbo(AA480) or 89 49 state(AA630) turbo ECU might work properly,but,I doubt it.
I picked up an AA480 and so far so good. The car seems to run although it would work fine before and then suddenly quit, so I need to get some miles under it to be sure. Now I'm getting codes 34 and 51 which are manageable and non-critical. We'll see how things progress.
Thanks for the replies, folks.
-Hamish
