TROGDOR! Posted May 1, 2006 Share Posted May 1, 2006 I'm working on a deal to get some WRX wheels with bad tires from someone locally, and found some cheap 225/50/16 tires in the paper. I calculated the diameter, and they're almost the same as the stock WRX tires. The question is... will these tires rub? Are they just too wide? Quote Link to comment Share on other sites More sharing options...
lmdew Posted May 2, 2006 Share Posted May 2, 2006 If it was an outback I would think they would fit, but on a Legacy, I think they will rub. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted May 2, 2006 Share Posted May 2, 2006 As long as they don't rub on the spring landing, anything else can be shifted with a 3lb hammer. test just the rim with the bald tire on a front and a back and see how it does. Quote Link to comment Share on other sites More sharing options...
subie94 Posted May 2, 2006 Share Posted May 2, 2006 strat put something close to that size on his legacy and he had hist lifted (i believe)--http://www.ultimatesubaru.org/forum/showthread.php?t=56879 his size was 215/65/16's Quote Link to comment Share on other sites More sharing options...
dmanaenk Posted May 2, 2006 Share Posted May 2, 2006 My bet is that 225 with stock suspension will rub. Having said that, there are different 225, and some might be fine.... Quote Link to comment Share on other sites More sharing options...
RallyKeith Posted May 2, 2006 Share Posted May 2, 2006 Stock STi wheels and tires rubbed on the inside of the rears on my 95 Legacy. The STi stock is 225/45R17. I was able to use a very thin spacer, something like 5mm ( I honestly don't remember) and get away with it. Of course then it rubbed the fender lip during heavy cornering. I was running crappy tires until they were bald so I didn't care about the rubbing. Keith Quote Link to comment Share on other sites More sharing options...
BruceyWV Posted May 2, 2006 Share Posted May 2, 2006 I'd say minimal rubbing would happen because of the big increase in width of the tire, but I'm not an expert. I've also got some tires here in my garage you're welcome to use if you want, just some old walmart specials my wagon came with though. Quote Link to comment Share on other sites More sharing options...
