May 24, 200619 yr so i have a 88 spfi gl wagon as you know. and i'm new to this so i am just wondering what i can do to increase hp. i've already researched and know what i'm goin to do for suspension (which will be done before increased hp ). but i dont know what is the best to do to an spfi to increase hp. any help?
May 24, 200619 yr The phrase, "As good as it gets" comes to mind. You might make a little more HP with delta cams and a port and polish of the heads. To get significant gains, you'd need to go with a turbo or swap in an ej22. Of course, a good tuneup will ensure you're getting the most the SPFI has to offer.
May 25, 200619 yr Could get 5 more HP by swapping to the MPFI heads, intake and wiring from a late model XT. (Rather than a port/polish, which probably wouldn't net you even 5). But that's a ton of work for 5 HP. Better off getting an EJ22. "As good as it gets" about covers it really. In more ways than one. Not just for HP, but for simplicity, and reliability too. GD
May 25, 200619 yr open the intake, and open the exhaust. k&n put a cone on a stock r32 golf, and it gained 32 ponies. so, getting a cone filter will get 2-3 ponies for you. muffler shops can make you a new y pipe for less than $300, and and the rest of the catback and whatnot for $200 or less. that might add 5 ponies. if it doesn't add much power, it will sound cool.
