June 7, 200619 yr Hi All, New here to the Forum and seeking some help in tuning a weber 32/36 dgav for my '90 model subaru brumby and it has the EA81 engine, I've just put the carby on, I'm assuming it came off a escort or cortina have several all being the same exept for the size of the main jets and air bleed jets. Anyway its seems better at certain throttle positions and idles ok but now the car seems to desiel on when turning it off it has a flat spot between idle and 1/4-1/2 throttle. the carby has 127 primary main jet 130 secondary main jet. 175 primary air correction jet. 135 secondary air correction jet. venturi thingy 4.5 primary venturi thingy 3.5 secondary ide jet primary 55 ide jet secondary 50 the carby also has the anti stall attached not sure if it is suppose to be removed or not. its a diafram located opposite the acelerator pump. Any help would be great anyone out there that may have already done the carby swap, jets sizes emulsion tube sizes. Any information on how the polution gear is set up properly with this carby. should I still use the anti backfire valve and the reed valve. Sorry this got so long Any help is appriciated Thanks Gumby
June 8, 200619 yr 140 primary 140 secondary 170 primary air corrector 160 secondary air corrector Both venturi's should be 3.5 Your idle jets are fine. I've never seen any difference in the emulsion tubes - I'm sure they make different ones, but all the weber's I've messed with were 50?? I think. Remove that anit-stall thing - don't need it. Remove your anti-afterburn valve, and your air injection reed valves - not needed unless you need them for air quality. Getting the deiseling to stop is all about timing, and idle mixture/speed. If you have the idle speed too high, or the timing off, this will happen. Easy way to stop it is to get the anti-deisel solenoid that Weber makes for the main idle jet. But you really don't need it if you tune it right. Acceleration flat spot is either the jets (probably) or could also be a bad accelerator pump. GD
June 8, 200619 yr Author Thanks heaps mate I'll try setting it up the same and see how it runs,on more question do you run the standard 6 deg timing? Thanks HEAPS!!!
June 8, 200619 yr I generally run the stock 8 degrees myself, or maybe a little less as my heads are milled a bit on one engine. GD
June 13, 200619 yr Author Thanks to everyone that helped me with this, I have finally got the weber running quite well I have ordered a few more jets but I end up with this with what I had around:- Primary main-132 Secondary main-140 Primary air correction-170 Scondary air correction-165 Primary Idle-55 Secondary Idle-50 NOTE:- This carby has no choke or choke plates they were removed a while ago (for a gain of about 3cfm) Seems to run very well even when cold, its a prick to start but once running, it will Idle slowly after a few minutes of reving at 1500rpm. I set the timing at standard 6deg (1990 Brumby ute). anti back fire valve and reed valve are disconnected. The carby changes the sound completely, The enginge revs quicker and smoother, Still a few flatspots though mainly at quater throttle and i thnk it could use a larger secondary main for the top end isnt much different to the old carby. When jets arrive will play and post results.
