Rx Low Idle
My ea82t is idling low. At start up it seems to idle about normal then it drops to about 500 and is very shaky. Rev it up, same thing falls to normal idle then drops again. If u live in the mass. area then you know it was raining very hard all day. So my initial thought was maybe some water might have gotten into the dist or that general area but bone dry. I just gave it a quick outside glance(in other words i didnt look at the inside of the dist cap for any moisture). Any ideas?:cornfuzz:
Sorry if this made no sense at all
Mike
Check for good spark plugs and wires, if its shakey it could be an issue with the ignition even if they've been done before check the connections and outside appearances on a disty are no indication of the inside, also if the plugs were just done make sure they are NGK cause if they arn't the car won't run for a darn especcially if they are bosch, those make them run like crap
