larrymc2000 Posted June 17, 2006 Share Posted June 17, 2006 My recently purchased 2000 Legacy developed a clanking or knocking noise coming from the engine recently. We haven't driven it since, worried that we may do more damage plus we've been on vacation. This seems to have occurred soon after an oil change and injector cleaning. The oil level is okay, prehaps a bit high. Any ideas ..suggestions??? Okay..additional info..Sounds like metal on metal, doesn't go away when warm, sounds link a loud ting, ting, ting, ting etc manual tranny. It's not a subtle noise, haven't cussed at it yet, I'm sure there's time for that later! Link to comment Share on other sites More sharing options...
Subaru_for_LIfe Posted June 18, 2006 Share Posted June 18, 2006 You have to be more specific, what kind of klanking sound? Metal to metal, metal to plastic? Auto or manual tranny? Does it vary with RPM? Does it go away after warmed up? Have you tried cussing at it? And no, I don't know much about anything, but someone who does will chime in shortly Link to comment Share on other sites More sharing options...
larrymc2000 Posted June 18, 2006 Author Share Posted June 18, 2006 Could this possibly be a push rod????? Link to comment Share on other sites More sharing options...
larrymc2000 Posted June 19, 2006 Author Share Posted June 19, 2006 or what??? Link to comment Share on other sites More sharing options...
nipper Posted June 19, 2006 Share Posted June 19, 2006 connecting rods (no push roads on an OHC engine) is a deep hollow knock. This can be a heat sheild, can be the starter drive, can be any number of things. Bad bearings dont sound tinny. How many miles on this. Does it change with the clutch or eingine rpm nipper Link to comment Share on other sites More sharing options...
larrymc2000 Posted June 21, 2006 Author Share Posted June 21, 2006 connecting rods (no push roads on an OHC engine) is a deep hollow knock. This can be a heat sheild, can be the starter drive, can be any number of things. Bad bearings dont sound tinny. How many miles on this. Does it change with the clutch or eingine rpm nipper 122,000 miles sound changes with engine speed, my son tells me he rev'ed first to 4500rpm and after that this started. Thanks in advance for any info you can give Link to comment Share on other sites More sharing options...
nipper Posted June 21, 2006 Share Posted June 21, 2006 122,000 miles sound changes with engine speed, my son tells me he rev'ed first to 4500rpm and after that this started. Thanks in advance for any info you can give that should have nothing to do with it, as these engines go to readline at full throttle. Quick test is to remove one plug wire at a time and see if the noise changes. If its a connecting rod the sound will change. Main bearings are never an issue. The noise should be fairly steady and a knoc knock knock sound. If its not it may be a cracked flex plate. try this test then ill give you something else to try next. nipper Link to comment Share on other sites More sharing options...
