July 28, 200619 yr So, I mostly started noticing this since I bought the wagon. Maybe its the XT rebelling against me. The XT's steering wheel is a bit difficult to turn. Its still very turnable, but some days its even really difficult. I also notice a whine coming from it so often. Is this a sign my P/S pump is going out? Fluid is topped off and normal. If the P/S pump is going out, does one off of any other DL/GL/GL-10/Loyale work (provided I change the pulley)?
July 29, 200619 yr Maybe the EA82 P/S Pump will Work, but I Suggest First to Change the Entire Power Steerin´ Fluid with the Better one you can Obtain, better if the new fluid got "Restoraton Additives" ... It has worked fine for both my Wagons... Good Luck!
