cd45 Posted July 31, 2006 Share Posted July 31, 2006 I have a 1987 Gl Wagon, 1.8, carbed, no turbo, 5sp, D/R. I need to get the A/C fixed. I want to change it to R134, so I can keep it charged myself. I called the local parts stores looking for a new drier, and no one has what I need. The one in the car has a switch at the top and the lines are 180 degrees away from each other. The local stores have one without a switch, and the lines are only 90 degrees out. If anyone has any ideas, please help. Link to comment Share on other sites More sharing options...
NorthWet Posted July 31, 2006 Share Posted July 31, 2006 All of my "L"-series have the 90 degree style. Did the Parts guys grab a book and trying matching yours to the illustrations? I have a NAPA Temperature Control book with lots of illustrations and several listings for Subarus around that year. If you can post a pic I can see if I can match to the book. *edit* - My guess would be NAPA 208651 (83-84 Subaru) DIA: 2-3/4in, Length: 7-1/4in, 16mm male fittings 180deg apart, site glass and 2 switch ports, no mounting flange. Tell me where its not right and I can try again Link to comment Share on other sites More sharing options...
NorthWet Posted August 4, 2006 Share Posted August 4, 2006 Any update? free BUMP Link to comment Share on other sites More sharing options...
Sonicfrog Posted August 4, 2006 Share Posted August 4, 2006 I fixed and converted mine this summer (frozen compressor, change o-rings), and I used the old dryer. This was two months ago and so far so good. I would make sure you change all o-rings and pull a vacuum on the system. Link to comment Share on other sites More sharing options...
