August 6, 200619 yr This is an aftermarket tach. (see pic) Would this have been a vent before the tach was installed? Strange-there isn't another hole like this on the passenger side. Would a tachometer like this have been added at the dealer? http://www.ultimatesubaru.org/photos/showphoto.php?photo=12171&cat=500
August 6, 200619 yr Andrew's wagon has the same tach,or at least one much like it and in the same spot. I have yet to come across a picture in my FPM's that shows a '73 wagon dash looking like yours and Andrew's.I'll keep looking.
August 10, 200619 yr Negative on that, there's supposed to be a hole in the dash for change or what have you. It's just a little cubbyhole on all '73s except the coupes, which came from the factory with a tach there in '72-'74, and models with the dealer-installed tach. It's not "aftermarket"-the dealer put it there. If I were you I'd leave it.
August 10, 200619 yr Author Thanks- I will. I have both trim pieces (for tach or coin box) If anyone wants the coin box, let me know. Its flawless. BT Negative on that, there's supposed to be a hole in the dash for change or what have you. It's just a little cubbyhole on all '73s except the coupes, which came from the factory with a tach there in '72-'74, and models with the dealer-installed tach. It's not "aftermarket"-the dealer put it there. If I were you I'd leave it.
