August 13, 200619 yr Hey, I have a 1993 impreza with the 1.8. I'm trying to remove the timing belt cover to access the oil pump. I've had no luck so far removing the crank pulley. The engine is out of the car. I have a long breaker bar on the crank bolt and and second one one of the cam bolts and haven't been able to break it. Should I just keep at it? Or is there a better way? Thanks, Dave
August 13, 200619 yr i just did this the other day and i used a penetrating oil all around the pulley and kinda wiggled it side to side and it came off .... they all dont always come that easy , be carful levering against other parts of the engine , i also have used a crankshaft puller looks like a tripod that has three arms that go on the back of the pulley and you screw a bolt down onto the crankshaft and it pulls the pulley off .... just keep workin at it . cheers blair
August 13, 200619 yr Author Its the bolt itself that I'm struggling with. We had alot of torque on it and it didn't budge. It's standard thread right?
August 14, 200619 yr You can do it with a very very large torquebar or you can use the starter to "bump" the bar and undo the bolt.
August 18, 200619 yr Hey, I have a 1993 impreza with the 1.8. I'm trying to remove the timing belt cover to access the oil pump. I've had no luck so far removing the crank pulley. The engine is out of the car. I have a long breaker bar on the crank bolt and and second one one of the cam bolts and haven't been able to break it. Should I just keep at it? Or is there a better way? Thanks, Dave See the following thread: http://www.ultimatesubaru.org/forum/showthread.php?t=62614 Especially the photo by Porcupine73. A Picture speaks a thousand words. Should be alot easier that way.
August 18, 200619 yr More leverage is the answer. I would hesitate to use heat on that bolt. It is a standard thread. I guess an air impact wrench is not in the picture. Seems to me with the engine out of the car you could put a pretty long pipe on the breaker bar and get plenty of leverage, I've got a six foot long piece of 2" steel pipe laying around just for days like this. The hard part is keeping the engine from moving around, or the crank from turning. Which piece of this are you having difficulty with?
August 19, 200619 yr Dangerdave you probably just need to lay on it. I had to put probably 300ft-lbs before I got mine to break on '00OBW. That took a good 3' pipe on the breaker bar. I hear the starter bump method works very well though I haven't tried it. Penetrating oil did me no good as bolt was in tip top shape just tight. Be sure when you put that bolt back in that you tighten it correctly (final tightness by degree not just torque). If that thing loosens up later on it can cause lots 'o trouble.
