November 5, 200322 yr Like...where is that at on FT4WD tranmissions? I found one that is on when its in gear, and i thinkits a DUH on the difflock switch, but the 3rd one...it doesnt work...diagrams?
November 5, 200322 yr That depends on which FT4WD you have ... Auto or Stick? If its Auto I can talk ya thru it without a FSM... if its stick... its off to the FSM for a looksee..... I have a reverse switch on the gear shifter from the auto to D/R 5spd conversion i did back in 2K springbreak.
November 5, 200322 yr Author i know where its at on an Auto. I went thru that. I need to know of a stick. Its the GL-10 in the sig.
