August 19, 200619 yr the lever that the vacuum actuator is attached to..is it pulled foward or pushed back to activate the diff lock?
August 20, 200619 yr Vacuum actuators usually pull - it's difficult to design ones that push, so if that's needed it's generally performed outside the actuator with a lever setup.... GD
August 20, 200619 yr Hey Callum This is Jerry, to engauge the diff lock it needs to be pull forward. Thanks Jerry
August 20, 200619 yr Author Vacuum actuators usually pull - it's difficult to design ones that push, so if that's needed it's generally performed outside the actuator with a lever setup.... GD hmmm the the vacuum actuator on my RX 'box is a double acting one thanks Jerry, i didn't get your post untill after i had found that out the hard way:lol:
