September 12, 200619 yr So had this GL-10 that I scrapped and I had the trunk left over. so with a welder and a butt load of scrap steel around you can built anything.. Took two 2 inch angle pieces and welded then to the rear of the trunk lid. Took a long 1/2 square tube and welded it between the two angle pieces. This formed the anchoring point for the rear of the table. Made some braces out of 1" x 1/2" solid bar and then secured them to the 2x4 in my garage. Placed the trunklid on top and then used a c-clamp to secure the braces to the rear bar. Weld to pieces together. Then weld the front of the braces to the trunk lid. I made the table about hip height so it's comfortable to work with while standing up. Will take pictures tomorrow b/c it's took dark. welders rule.... BW
November 10, 200619 yr Author ok so here are some pictures. here is a picture of the brace One more thing that I did w/some left over parts. I took a gas tank and some steel wheels and made a parts cleaner. there part in the cleaner is 1/2 of an ea81 block. Here is the other half all nice and clean. BW
November 10, 200619 yr Author yeah. work's been really slow so I have had a lot of time on my hands. I am proud to be a member of the Crimson Napes. BW
