ej2.71 stroker
What engine are you starting with? Why do you think you would have to do anything to the ECU?
I have an ej25. My friend told me he thought I might have to do something to the ecu?
any decent machine shop can offset grind your crank but the custom rods will be a pain unless there is another application that has a smaller rod journal than the ej25 crank and the proper length and pin diameter. I bet there is something close out there somewhere just takes a lot of searching.
I seriously doubt that there is a suitable connecting rod in another application. The Subarus are already a pretty short stroke/compact engine, and you are now talking about an even shorter rod.
