drquasievil Posted October 17, 2006 Share Posted October 17, 2006 I have a 95 Legacy LS with 80+K miles. When making a left turn and accelerating, I hear a rattle noise. I did a few 360 turns both left and right and no rattle. I have 4 new tires. Help please. Quote Link to comment Share on other sites More sharing options...
feathersjr Posted October 17, 2006 Share Posted October 17, 2006 I have a 95 Legacy LS with 80+K miles. When making a left turn and accelerating, I hear a rattle noise. I did a few 360 turns both left and right and no rattle. I have 4 new tires. Help please. It sounds like the axle on the front left:-\ Check to see if the boot is torn on the left side. The axle is easy to replace, about an hour. After market replacement axle around $100. Some people say to replace your axles in pairs, I'm not one of them:headbang: You might check your heat shields on the exhaust system to make sure they have not come loose. Good luck, feathesjr Quote Link to comment Share on other sites More sharing options...
drquasievil Posted November 11, 2006 Author Share Posted November 11, 2006 It sounds like the axle on the front left:-\ Check to see if the boot is torn on the left side. The axle is easy to replace, about an hour. After market replacement axle around $100. Some people say to replace your axles in pairs, I'm not one of them:headbang: You might check your heat shields on the exhaust system to make sure they have not come loose. Good luck, feathesjr All I confirmed that the boot is broken on the left side. Beside the rattle is is dangerous driving with it? Does it need to be replaced immediately? Thanks Quote Link to comment Share on other sites More sharing options...
JPX Posted November 11, 2006 Share Posted November 11, 2006 All I confirmed that the boot is broken on the left side. Beside the rattle is is dangerous driving with it? Does it need to be replaced immediately? Thanks CVs can go a surprising distance even when contaminated after a boot splits. I think I drove almost 10K miles on mine. With the bad weather going on, this distance becomes much shorter. If you overdo it, it will require a wheel bearing change if a bad outer CV overheats the bearing. Check another boot - the one from the steering rack to the hub. This was the source of my rattle/clunk. Quote Link to comment Share on other sites More sharing options...
drquasievil Posted November 11, 2006 Author Share Posted November 11, 2006 CVs can go a surprising distance even when contaminated after a boot splits. I think I drove almost 10K miles on mine. With the bad weather going on, this distance becomes much shorter. If you overdo it, it will require a wheel bearing change if a bad outer CV overheats the bearing. Check another boot - the one from the steering rack to the hub. This was the source of my rattle/clunk. Thanks the info JPX Quote Link to comment Share on other sites More sharing options...
drquasievil Posted November 11, 2006 Author Share Posted November 11, 2006 CVs can go a surprising distance even when contaminated after a boot splits. I think I drove almost 10K miles on mine. With the bad weather going on, this distance becomes much shorter. If you overdo it, it will require a wheel bearing change if a bad outer CV overheats the bearing. Check another boot - the one from the steering rack to the hub. This was the source of my rattle/clunk. Two more questions. 1- Should I replace them both, the other is still good 2- Do I need a wheel alignment after replacement Thanks, Quote Link to comment Share on other sites More sharing options...
tcspeer Posted November 12, 2006 Share Posted November 12, 2006 I think the answer to both questions is no. If you follow the directions in the Haynes manual for removing and replacing the axle, you wont need a wheel alignment. Two more questions. 1- Should I replace them both, the other is still good 2- Do I need a wheel alignment after replacement Thanks, Quote Link to comment Share on other sites More sharing options...
Dickensheets Posted November 12, 2006 Share Posted November 12, 2006 I just did mine last week. It was my first time. It was amazingly smooth via the hayne's manual. Here is my list of tools used: Jack Jack stand Small chisel (or screw driver) to unstake axle nut 32mm socket for axle nut 24" breaker bar for axle nut 14mm (i think) socket for ball joint pinch bolt Small prybar (big screwdriver) to pop the ball joint out of position Pin punch from sears (really important to get right size, I'm not at home right now or i'd look) Small hammer to drive pin Set of spouse hands covered in gloves to pull on strut gently while I guide axle out of tranny Enjoy, rd Quote Link to comment Share on other sites More sharing options...
