October 23, 200619 yr hi, im new to the board, i have an 83 wagon turbo automatic push button 4wd. i bought it for 200$ and its in mint cond has 94k original miles and no damage. the only problem it has is about every 6-9 months it tears up a govenor gear, has anyone else had any issues with this or know how to fix it:confused: ? i looked around the site and could not find anything helpfull. also just out of quriosity how much boost do these things push stock? this is my first subaru. im a mechanic and have been for about 8yrs but i work at a ford dealership so this subaru thing is new to me. any help would be greatly appreciated:) . thanks. tom
October 23, 200619 yr Sadly, this indicates the governor drive gear inside the transmission is damaged. It can't be replaced without removing and dismantleing the transmission. Your best bet is to find anther tranny. Or even better - just put a 5 speed dual range into it. Easier to find, and many, many times more reliable that the 3AT. GD
October 23, 200619 yr Author Sadly, this indicates the governor drive gear inside the transmission is damaged. It can't be replaced without removing and dismantleing the transmission. Your best bet is to find anther tranny. Or even better - just put a 5 speed dual range into it. Easier to find, and many, many times more reliable that the 3AT. GD what parts do i need to find for a 5 spd swap and from what yrs?
October 23, 200619 yr Lots of threads on that! Here's some stuff from the online repair manual, and you should do some searches too. http://www.ultimatesubaru.org/forum/showthread.php?t=49952 http://www.ultimatesubaru.org/forum/showthread.php?t=54203 You should contact Bratsrus1 (Jerry). He makes a great little install kit that will make the whole process a breeze. GD
