ShakotanBoogie Posted October 26, 2006 Share Posted October 26, 2006 Is this as straightforward of a swap as it should be? Searched and didn't find much; we're thinking of dropping an early EJ22T from a Legacy SS into my '95 OBW just for the novelty of it (it is Trashwagon 8 after all). I'm told that as far as the ECU goes you just have to ground a pin and it thinks it's a turbo - this true? Quote Link to comment Share on other sites More sharing options...
Manarius Posted October 26, 2006 Share Posted October 26, 2006 OBDI engine into OBDII - not a fun experience. Aside from electronic issues, the engine would go in just fine. Quote Link to comment Share on other sites More sharing options...
ShakotanBoogie Posted October 27, 2006 Author Share Posted October 27, 2006 Shouldn't '95 still be OBD-1? Quote Link to comment Share on other sites More sharing options...
Manarius Posted October 27, 2006 Share Posted October 27, 2006 Shouldn't '95 still be OBD-1? No. 1995 Subaru started with OBDII. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted October 28, 2006 Share Posted October 28, 2006 Wiring would be doable, but you still have the age old problem of swapping a turbo engine into a car that didn't have one origionaly. Exhaust would have to be custom, wiring modified, and a lot of effort put in. I would do it, but I also have no problem modifying the snots out of my car. Yes, you could do it. But $$$ and lots of downtime would be involved. Why not run the legacy ss that you're getting the engine from? Quote Link to comment Share on other sites More sharing options...
ericem Posted October 28, 2006 Share Posted October 28, 2006 wasnt there something different on the engines? Like 2 exhaust manifolds i dont know something 2 instead of 1? or was this after 97 mid? Quote Link to comment Share on other sites More sharing options...
Manarius Posted October 28, 2006 Share Posted October 28, 2006 wasnt there something different on the engines? Like 2 exhaust manifolds i dont know something 2 instead of 1? or was this after 97 mid? 100% irrelevant. The motor mounts are the same, the exhaust makes no difference. If any thing, he'd have to somehow get his hands on a turbo cross member, but that's it otherwise. Quote Link to comment Share on other sites More sharing options...
xrturbo Posted October 28, 2006 Share Posted October 28, 2006 if you actually decide to do this keep me posted please. i have the exact same cars, and was thinking on one of the 95's doing an sti swap but cheap is always better, already have the ss with a bad trans. Quote Link to comment Share on other sites More sharing options...
