Seamarshal Posted October 30, 2006 Share Posted October 30, 2006 Bought a 99 L model and the door open lite on the dash stays on when I turn the key off; when I lock the car, the door lite goes out. I've replaced the drivers side door on/off switch, as it was loose. Any help?? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted October 30, 2006 Share Posted October 30, 2006 Hi Seamarshal and :welcome: ! Does it have a separate indication for each door and the hatch (if so which one is illuminated?) or just one general indication? Those door switches as you've already said you replaced the driver's door one I've found can get a little fussy with corrosion and stuff over time. Does this issue make your dome lamp stay on (provided it's switch is set to come on when a door is open)? Quote Link to comment Share on other sites More sharing options...
