Cant get the blower motor to turn on
did you give the motor 12 volts? what vehicle, year, model?
any symptoms or previous funnies...or did it just quit working one day? do the buttons light up when you turn it "on"? it doesn't come on with a/c or anything?
you can't find what unit in the air duct? the blower motor was replaced?
1986 subaru sedan. it went into les shwab and came out with a blown cd player and the blower motor quit working, where is the unit in the air duct?
You most likely have a bad blower relay. I think it is located under the dash, near the end, on the driver's side. If not there then the middle of the dash. You may be able to locate it by tapping on the relays with the power on to the blower and see if it will make it run.
ill try that but i might just bypass it. im tired of looking. thanx for ur help. and the relay will look like what for this 86?
My info for a '88 shows there are four relays near the middle of the dash. The first one in line is the blower relay. The relays a usually round and about 1 inch in diameter. They plug into sockets.
You should use a test light to check for power getting to the blower and the CD player.
I'm not sure since I have never had to replace one but a number of folks here have had to. Now that you kind of know what to look for it may help you spot them.
