November 9, 200619 yr Sure - but do both sides if you are going to do it, and get some Fel-Pro HG's too. The rocker bolts slip through holes in the frame - there's rubber plugs you remove, and retrieve the bolt from behind the wheel well. The heads will slide right off no problem. GD
November 9, 200619 yr Author Sure - but do both sides if you are going to do it, and get some Fel-Pro HG's too. The rocker bolts slip through holes in the frame - there's rubber plugs you remove, and retrieve the bolt from behind the wheel well. The heads will slide right off no problem. GD Sweet. Thx.
