buzzcon Posted November 12, 2006 Share Posted November 12, 2006 I got an '88 ea82t. The hose running from the thermostat housing to underneath the intake, is leaking at the thermostat housing. To get to the part underneath the intake, can I pull the throttle body, to get to the hose, or do I have to pull the intake? Please say I don't have to pull the intake. Please say this is a piece of cake. If you say I have to pull the intake, how much will be involved? I just replaced the pita turbo hoses. Now it's leaking up front! Thanks ~Myles~ Quote Link to comment Share on other sites More sharing options...
baccaruda Posted November 12, 2006 Share Posted November 12, 2006 that thing sucks. I recommend a pair of angled needlenose pliers or angled-nose hemostats, and a hand mirror. maybe a flashlight beamed off of the mirror too if you have a flashlight that doesn't taste bad or someone else to hold it. If someone used a hose clamp instead of a tension clamp you're pulling the intake. Another option would be to clip the hose off short of the thermostat housing and splice the clipped-off length back on with some bulk hose and a joiner of some sort.. this of course will require 2 more clamps. Not a permanent fix but maybe good enough to last the winter, fix it when it's warmer outside later Quote Link to comment Share on other sites More sharing options...
baccaruda Posted November 12, 2006 Share Posted November 12, 2006 also, there should be some coolant hoses involved with the throttle body. At some point, a turbo car needs all of it's coolant lines replaced. The extra heat underhood from the turbo just cooks them all. the more dramatic temperature changes a car experiences in the winter might mean you'll have more to fix.. i seem to recall a lot of my turbo cars' coolant lines popping when it was cold. FYI.... Quote Link to comment Share on other sites More sharing options...
buzzcon Posted November 13, 2006 Author Share Posted November 13, 2006 Thanks a lot. There was a pinhole right at the thermostat housing, so I cut the bad section off and added a hose fitting and a new section with clamps. Works great. I hope your right and I can get to warmer days before having to tear into it. Ohhhh, for a garage . ~Myles~ That's my 2 cents and it's worth a nickel Quote Link to comment Share on other sites More sharing options...
