Matching transmissions to rear ends\differential.... 95\96
Finding conflicting info on matching trannies to rear differential (and how to even tell what rear end I have)..
My 1996 OBW 2.5\4EAT engine and tranny went south.... Looking for:
1. First choice 1995 EJ22\4EAT combo out of the same (crashed) car
2. 1995 EJ22 and 1996 4EAT from seperate cars...
Question still looms:
A. How do I know what my current rear differential ratio is? (is pulling the plug and counting "teeth" the only way? How many count for what ratio?
B. How will I know what rear end option #1 needs (4.1 or 4.44?)
Since they seem to be so cheap, even tempted to
- Try to find out what I have
- Pick up "the other", so I have both on hand...
Some folks claim
EJ2.5 automatics are all 4.44
manuals are 4.1
But that might diverge with 2.2....
I'm getting the impression that this might be a trial and error deal...
Opinions? :confused:
http://www.ultimatesubaru.org/forum/showthread.php?t=67201&highlight=rear+differential+4.1
i went to car-part.com and searched for rear diffs for 2.5's manual and a/t and 2.2 manual and a/t legacy / outback. what i learned is below.(AND THIS IS NOT DEFINITE, DO YOUR OWN REASEARCH) and i'm working from memory, but i posted this in the last 2 months so a search would show what i knew, not what i remember.
'95 - '99
2,5's = outback's & gt's are 3.9 manual and 4.44 a/t
2.2's = legacy's 3.9 manual and 4.11 a/t
peoblems:
95 and 96 were transition years for the 2.5 engine / trans. so there is /was not enough information to assume that they matched the 97 -99 years. in other words, it is possible that 96 2.5 at had a 4.11. i don't know that they did but idon't know that they didn't. same for 95, only less so. did they even offer the 2.5 in 95??? by 97 the outback / gt was set at 2.5.
now for corrections:
i have been corrected before and i don't argue the point, but ... the trend seems to be what i have stated above.
the other thing to do is to compare the tranny numbers. tz102z2xxx is a 2.5 a/t (97 - early 99, maybe 96 to 99). tz102zAxxx is a 2.2 a/t.(in a 95 2.2L leg sedan. i swapped a 96 2.2 leg wagon a/t into the sedan with no problems so i assume that the 96 is an 'A' as well. i did some tranny number research last year and posted, more searching might confirm. try "tz102zaaaa")
i don't have or know part numbers for manual transmissions, sorry. when searching legacy rear "carrier"s (differentials) the first question they ask is 2.5 or 2.2. they then go to mnaual or a/t .
conclusions: (and this is a strech)
manuals are 3.9 and a/t's depend on the engine. (DO YOUR OWN RESEARCH)
get a tranny that matches your engine/tranny model and year!!!!! if not get the diff to go with it. especially if you are changing from 2.5 to 2,2.
when in doubt , call the dealer give them the vin and ask, for both the donor car and the receiving car. i recommend 2 dealers just ot be sure. some parts guys are not the sharpest knives in the drawer.
regarding gear ratios and teeth:
i also found a reference to the 4:44 ratio in the 96-99 2.5L a/t as 40 x9 teeth (40 ring gear and 9 pinion gear). if this is the case then the 4:11 ratio will have 37 teeth on the ring gear and 9 on the pinion; and the 3:9 will have 35 teeth on the ring gear and 9 on the pinion. any one know if this is acurate? and is it more or less work to swap a ring gear than a rear diff. ?? my guess is more. but knowlege is power, and more is better.
http://www.ultimatesubaru.org/forum/showpost.php?p=520095&postcount=9
good luck, john
PS i spotted a complete 91 legacy LS 2.2L sedan awd a/t abs today in a salvage yard, keys on the front seat. wrecked front, (bad front bumper grill, hood, etc. and dented left side all the way back.) last driven before something /03, inspection sticker was '03. your guess is as good as mine about the engine but the tranny might/should be good. miles were either 61k or 161k. if interested let me know, i'll double check and ask about it.
John,
Thanks, very much appreciated...
Will add the rearend to my wish list (esp. if I can find a 95 Legacy with a 2.2\4EAT) will try to grab the whole drive line... sounds\feels like this should give me a 4.11, so will give me some latitude when I try the swap.
I will definately be sticking with an automatic so will be spending the weekend (pending the impending ice storm that we are threatened with!), counting teeth! (and combing for wrecks...) .
-John
'95 - '99
peoblems:
good luck, john
