oronocova Posted December 4, 2006 Share Posted December 4, 2006 Hello all, I searched for something on justy alignment but found none. I just recently replaced my LR wheel bearings on my 90 Justy 4x4. In doing so the hub was removed to get them pressed in. It seems to me there is some sort of "click" adjustment on the hub... probably for the toe-in/out. But then again, I don't know much about aligning a car other than taking it to a shop. I just eye-balled it fairly straight, but am I right in thinking this will mess up my toe? / Should I have it checked/realigned? TIA, Jon Quote Link to comment Share on other sites More sharing options...
RONAN Posted December 4, 2006 Share Posted December 4, 2006 Are you sure your not talking about the brake drum adjustment??? Quote Link to comment Share on other sites More sharing options...
oronocova Posted December 5, 2006 Author Share Posted December 5, 2006 I am talking about the marks on the long bolt that connects the hub to the lower control arm. If you look at the hub it has little marks on it that "snap" it into fixed positions. The nut must be loosened then the hub can be moved, and when the nut is tightened back down the hub will be fixed in that position because of the groves. For some reason I am having a hard time explaining this... sorry :/ Anyway, the only thing that it seems it would affect is the toe? Thanks, Jon Quote Link to comment Share on other sites More sharing options...
bushbasher Posted December 5, 2006 Share Posted December 5, 2006 yeah, I think you are right, its for toe in. Mine are frozen, so I cant adjust it (its really toed in alot, I think all justys are stock. Quote Link to comment Share on other sites More sharing options...
oronocova Posted December 6, 2006 Author Share Posted December 6, 2006 well... thanks. i'm pretty sure that is what it is adjusting. i'll have to run it and see how the tire wears. thanks for the replies Quote Link to comment Share on other sites More sharing options...
oronocova Posted December 8, 2006 Author Share Posted December 8, 2006 well... thanks. i'm pretty sure that is what it is adjusting. i'll have to run it and see how the tire wears. thanks for the replies as i was driving along yesterday i realized in thinking about my post that i have been saying "toe" when actually what i meant was camber. the adjustment is for the camber not the toe. oops. just a post incase someone else reads this in the future, as to not confuse them. thanks again Quote Link to comment Share on other sites More sharing options...
