December 15, 200619 yr I did a search but found nothing. Anyway to reset the ECU on a 92 Legacy NA 2.2L 5spd?
December 15, 200619 yr Pull the battery cable for 45 minutes or pull the ECU fuse for 45 minutes. Put the car in neutral, put the ebrake on, put the fuse or cable back on, and start the car. Let it get to running temp or 10 minutes - whatever comes first. Then shut the car off. Do not touch the gas or anything.
December 15, 200619 yr Or the factory manual method: Igniton - OFF Connect the black and green connectors under the steering column. Both are single wire, normal-state is disconnected. Igntion - ON Press the throttle to the floor. Lift it back to approx. half-way, hold it there for 2 seconds. Release throttle fully. Ignition - START! Let the engine run for a few seconds, the CEL will be off if there are no present faults. Start driving....sooner or later, within minutes, the CEL will flash at a steady rate, indicating the ECU is reset. Igntion -OFF Disconnect both green and black wires. DONE!
December 15, 200619 yr SetRight, that method only clears the codes, it does not reset the entire ECU.
