December 16, 200619 yr i'm stumped my xt-6 runs fine, but it is verfy hard to get it started you have to pump the gas and crank it for atleast 15-20 seconds before it will start
December 16, 200619 yr CTS? Does it idle fine and run well once started? My wagon would be hard to start when cold. It was the CTS wires. But it caused to have a rough idle and would stumble until warm. If yours runs fine once started cold, it probably isn't the CTS.
December 16, 200619 yr i'd go with what mike said, coolant temp sensor. Also, make sure the easy items like your plugs and wires are good, and check your timing.
December 16, 200619 yr Author the timing is way advanced i checked all my plugs this afternoon i guess it's time to replace the wires in the harness:mad: sad panda
