Uberoo Posted January 4, 2007 Share Posted January 4, 2007 I am trying to make a template for my EA-EJ swap.So far I have the engine side of the adapter(ej22) holes drilled in plywood,but what do I align the D/R 5 speed to to get perfect alignment?Money is tight right now so I can't just buy an adapter.thanks in advance. Link to comment Share on other sites More sharing options...
Reveeen Posted January 4, 2007 Share Posted January 4, 2007 I am under the *understanding* that the bottom 2 bolt/stud holes between the two, EA-EJ, are in the same location, so you would work around that. If you look at the availaible adapters that is how it appears. Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 4, 2007 Share Posted January 4, 2007 I have a cardboard template of the adapter plate that i have, that i traced when i had the motor out, i'll trace you a copy of it and add it to your bill Link to comment Share on other sites More sharing options...
Uberoo Posted January 4, 2007 Author Share Posted January 4, 2007 noah can you trace both sides!? NOAH IS GOD!NOAH IS GOD!NOAH IS... Link to comment Share on other sites More sharing options...
