January 5, 200719 yr Brand new in box carb fits toyota hillux 1969-1971 anybody out there know if it can be fitted on a 1987 subaru gl wagon gl. I can get it for $75.00 Would I have to go machine shop route to get conversion plate?
January 8, 200719 yr I think probably not, but the easy way to find out is to just pull off your carb and see if the new one fits. If you're good with a plasma cutter and a set of files you could make your own adapter plate - it's the Subaru way! Good luck.
May 23, 200718 yr i think it won't fit.. anyways, it would help to ask a trusted mechanic or the dealer if that carter carburetor would fit on a 1987 subaru gl. this way you'll have more info.. good luck
