jeep5.9litre Posted January 11, 2007 Share Posted January 11, 2007 I was wondering if you can adjust the vehicle posture from anywhere on the EA82 series 4WD wagons as you can with the EA81 wagons? I was looking on my brothers 89 GL and couldnt seem to find anything. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 11, 2007 Share Posted January 11, 2007 Probably not on an 89. The 85/86(maybe some 87) 4WD rear coil-overs had 3 adjustment notches that you could change with a pair of channel locks. Later coil-overs didn't have the adjustment notches. Front struts are the same as EA81's - there's two lower spring perch adjustment nut's to raise the front suspension. GD Quote Link to comment Share on other sites More sharing options...
Subieguy Posted January 11, 2007 Share Posted January 11, 2007 Not going to happen on an 89. You will have to go get some struts out of a 85 if you want to make adjustments. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 12, 2007 Share Posted January 12, 2007 Not going to happen on an 89. You will have to go get some struts out of a 85 if you want to make adjustments. My 86 has them also. GD Quote Link to comment Share on other sites More sharing options...
jeep5.9litre Posted January 12, 2007 Author Share Posted January 12, 2007 Ah I gotcha..Thanks for the info! Quote Link to comment Share on other sites More sharing options...
