January 14, 200719 yr I am just getting into modifying some things on my 96 Legacy sedan. Right now I am looking at adding some Driving lights and Fog Lights. I was looking at different Hella kits for this. I dont have much experience wiring cars but I have done small electrical work in the past. My main question is how hard is it to wire everything for the lights, also are there additional spaces available for the relays and fuses for the lights. Any help would be great, I tried searching for similar topics but could not find much.
January 14, 200719 yr i have installed lights on several vehicles in the past, are you looking to install them with factory wiring or wire them seperately?
January 14, 200719 yr Author Wire them with seperate wiring that comes with the kits. And also I was looking to install them on the front bumper.
January 14, 200719 yr front bumper is toughish....do a search "driving lights" maybe. A couple people have done it. Wiring it is easy, hardest part is going throught the firewall which is very easy.
January 14, 200719 yr Author My main concern was with the relay/fuse setup, if there was room in the existing electric compartments.
January 15, 200719 yr I have done it. I used hellas and used thier kit, but i went with a differnt switch (its in my phots). I made a 90 degree bracket and mounted all my relays in front of the battery on my 97 as they fit really nice there. The bumber skin i used self tapping screws that came with the kit (start them with a pilot hole but tighten by hand). The skin is thick and after a year they are still tight. nipper
