pBIIKS Posted January 16, 2007 Share Posted January 16, 2007 I have an electrical problem with a 2005 2.5 XT outback wagon. Driving to work this AM I had the headlights and fog lights on when I noticed that every so often both the radio display and the temp display would dim and then go back to being bright. Later I noticed that the trip OD would flash ILL.5 and then this changed to ILL.6 before going back to giving the mileage. Does anyone have any idea as to the problem? Thanks. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted January 16, 2007 Share Posted January 16, 2007 I have an electrical problem with a 2005 2.5 XT outback wagon. Driving to work this AM I had the headlights and fog lights on when I noticed that every so often both the radio display and the temp display would dim and then go back to being bright. Later I noticed that the trip OD would flash ILL.5 and then this changed to ILL.6 before going back to giving the mileage. Does anyone have any idea as to the problem? Thanks. http://www.ultimatesubaru.org/forum/showthread.php?t=70073&highlight=Ill6 Quote Link to comment Share on other sites More sharing options...
pBIIKS Posted January 16, 2007 Author Share Posted January 16, 2007 http://www.ultimatesubaru.org/forum/showthread.php?t=70073&highlight=Ill6 Thanks Johnceggleston. I must have a loose connection or a short on the dimmer switch since I wasn't adjusting it. Quote Link to comment Share on other sites More sharing options...
