What engine temp (in degrees) do you XT6 owners normally see?
I am trying to figure out if I am running hot or not. Can you XT6 owners give me some normal temp readings? I am not using the XT6 guage so guage position will not help.
Mine normally runs between 110 and 120. I wouldn't think that you would be running hot with that monster radiator you've got, unless you suspect a problem.
Assuming we both mean Celsius then I am dead on what you are seeing. It is just that this CR is running a bit warmer.
