November 20, 200322 yr Fan works fine first time I turn it on. Stop somewhere and turn the car off and restart after a few minutes (gas up) and the fan acts like its not getting power. Turn the car off and leave it for a while and the fan will work again when the car is started. Anyone have an answer to the reason for this?
November 20, 200322 yr It may be that the heat buildup from the engine is causing problems with the heater resistor? Mine was replaced by the PO at a cost of about $50.00. Jw
November 21, 200322 yr I had a fan blower that would do almost the same thing. Would start ok & then would not start sometimes. My vehicle had about 200K miles on it at the time. Pulled the blower motor & was full of carbon dust from commutator brushes. Got a new one for around $30 - $40 & problem solved.
