February 6, 200719 yr Hi. I'm having to replace a front half-shaft on my 1988 GL-10 Turbo wagon. It's a 4-speed AT full-time 4WD. I've read through some of the past postings, but am still slightly confused. From what I've seen it appears that MT Turbos have a 25-spline count on the shaft and AT Turbos have a 23-spline count on the shaft. Is this correct? I'd like to make sure that I'm getting the right one before I go ordering the thing. Thanks much.
February 6, 200719 yr i to own a 88 gl-10 that came with a 4-speed auto. i converted it to the 5speed dr. had to change the axles to smaller ones. never did count the splines and i believe the 25 spline are larger, so my vote will be, yours will have 25 splines. hope this helps del
February 6, 200719 yr Author Never mind. Got the answer from Calebz. The 3-speed AT turbos are 23-count. The 4-speed AT turbos are 25 count.
February 7, 200719 yr I have a full time 4WD 4speed automatic in my GL. It does in fact have 25 spline stubs. 3speeds have 23. I always end up having to order the axle for the manual tranny turbos. The part stores just don't have enough info about the fulltime 4wd models
