pushbar install question
1 bolt in each tow hook, 2 where the liscence plate goes on, and 1 right on the top center. it should be a fairly easy install. there are sturdier methods to put it on, but this would be the easiest. only 3 holes that need to be drilled. 5 bolts w/washers needed from the hardware store.
  • 3 weeks later...
