Uberoo Posted February 18, 2007 Share Posted February 18, 2007 I am doing the EA-EJ swap(more like the never ending swap) Anyway I have a question concerning the O2 sensor.When I pulled the 90 legacy EJ22 someone had removed most of the Y pipe.I have the headers that come off the engine but no y pipe if that makes sense.Also when I pulled the harness from another 90 legacy it didn't have O2 wires(nothing had been cut either) did the 90 legacy with ej22 have an O2 sensor?Could you please post pics of your stockish* Y pipe and O2 sensor location. *Can be oversized pipe just stock layout. Quote Link to comment Share on other sites More sharing options...
OB99W Posted February 18, 2007 Share Posted February 18, 2007 Sorry, I don't have a '90, so can't provide a pic. However, AutoZone's "Component Locator" says: "On your 1990 Subaru Legacy, the Oxygen Sensor is: Under hood, passenger side, lower engine area, below exhaust pipe flange, mounted in exhaust pipe" http://www.autozone.com/servlet/UiBroker/?UseCase=C001&UserAction=performQuickPartType&Parameters=%7C%7EAuto+Store%7C%7ECOMPONENT+LOCATIONS%7C%7EOxygen+Sensor Quote Link to comment Share on other sites More sharing options...
Richard1296 Posted February 18, 2007 Share Posted February 18, 2007 My 90 Legacy AWD (EJ22/auto) has an O2 sensor. I had to replace it. The connector for it is on the right side of the engine close to the intake manifold. It could easily be overlooked. Richard Quote Link to comment Share on other sites More sharing options...
Uberoo Posted February 18, 2007 Author Share Posted February 18, 2007 do you have pic of that connector by chance? Quote Link to comment Share on other sites More sharing options...
Richard1296 Posted February 18, 2007 Share Posted February 18, 2007 My son has the car right now, no idea when I'll see either of them. It's a square grey four pin connector. The connector on the wiring harness should be a female connector. The connector should be near the right rear, under the edge of the intake. I'm thinking it has BLUE, WHITE, and two BLACK wires. I've also learned not all Subaru's of the same year are the same. Richard Quote Link to comment Share on other sites More sharing options...
Uberoo Posted February 18, 2007 Author Share Posted February 18, 2007 I just have a flat 3 connector that goes to cam angle sensor,a flat 3 connector that goes to crank angle sensor,and a 1 wire connector that goes to the knock sensor.Nothing else under intake.Then I have 3 square connectors that come from the left fender.Does dis mean I dont have an O2 sensor?I suppose I could wire everything up,put the motor in and see if starts and throws "o2 sensor" codes... Quote Link to comment Share on other sites More sharing options...
Richard1296 Posted February 19, 2007 Share Posted February 19, 2007 There should be a harness that comes onto the right side of the engine from inside the car. It should branch off for the purge solenoid and coolant temp sensor. Near there should be another 4 pin connector for the O2 sensor. If I had the car here I could tell you more. Its been a year since I was under the hood of it. But since I had to replace the O2 sensor and purge solenoid I am pretty sure of the locations of most connectors on that side of the engine. The locations are the same on my 2000 OBS, though the connectors are different. Look on any 2.2 engine for the O2 sensor harness. It will be in the same location on the engine. Richard Quote Link to comment Share on other sites More sharing options...
