skishop69 Posted February 25, 2007 Share Posted February 25, 2007 Ok, I've got my motor back together and I'm almost ready to put it in. I got axels and of course they were wrong. NAPA only shows one number and Schmucks has to special order them. I know the local NAPA has them at the wherehouse, but I need more info. What other years/makes will fit this thing? I wanna button this thing up today. BTW, this is the FT4WD with Spider. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 25, 2007 Share Posted February 25, 2007 go for an '89 GL-10 turbo 5-speed, those will work... Quote Link to comment Share on other sites More sharing options...
suberdave Posted February 25, 2007 Share Posted February 25, 2007 any EA82 Turbo Axle should be the same... -=Suberdave=- www.suberdave.com Quote Link to comment Share on other sites More sharing options...
Gloyale Posted February 25, 2007 Share Posted February 25, 2007 any EA82 Turbo Axle should be the same... -=Suberdave=- www.suberdave.com No actually, any 3spd automatic car, even with turbo, has 23 spline axles. He needs 25 spline. So you can't just say turbo. espescially before 89 when they dropped the 3spd in turbo 4wds. it stayed for the 2wds. Anyhow, lookin it up as a 4wd turbo MT should work should work, regardless of year. I did get an axle once that was all correct except it had the wrong length shaft. too short to make it to the stub! just a mistake at the reman place I guess. Quote Link to comment Share on other sites More sharing options...
skishop69 Posted February 26, 2007 Author Share Posted February 26, 2007 Actually, we went to the books and matched by spline count and length, then back tracked the part number. I came up for the same year turbo 4spd auto. Go figure.... Anyway, the car is running and when I have some more time, I'l post the entire fiasco. Quote Link to comment Share on other sites More sharing options...
