Intermittent wiper module - 2k obw
Does anyone know where the intermittent wiper control module is located? Is it integrated into the wiper control stalk?
I believe it is failing in my car. Both the mist (pull the wiper stalk for a single sweep) and the intermittent settings often will not operate the wipers at all. For example, I sometimes have to pull on the stalk multiple times before it will actually sweep once. On intermittent, the wipers will either not operate, operate at very delayed intervals, act very slow, or stop in the middle of the sweep.
The wipers act normally in both slow and fast modes. They also work normally when the washer button is pushed - two sweeps.
Steve
I'm not sure if this is the correct module but my data shows a Mode Actuator under the center of the dash and is where I would expect to find this kind of thing.
